- Replies 8
- Views 2.3k
Manimalmother 3 posts
dripley 2 posts
Dieselfuture 1 post
Marcus2000monster 1 post
Popular Days
I drilled a small hole in the bottom of the pod my gauge is in just for that reason. Shortly after I installed mine I smelled diesel and just wiped my finger over the hole and sure enough it was wet.
You should have. Its not really a fuse it just makes the blink. Your hazard flasher is in there too. I beleive it is the black one. The silver one is for hazards IIRC.
I also installed a electronic flasher to fix the led fast flash. I used a Napa EP-27L flasher. I got the part number from a M1973M post last week, wish I could link it. Lol
So I just got in the truck to leave work and noticed that my turn signals are not functioning. My windshield wipers will turn on with the multi-function switch, and my hazards work. No turn signal indicator is lighting up on the dash no audible click from the blinker. Any ideas? What to check first?
Well I found the cause of the problem. The compression fitting on the back of my fuel pressure gauge was leaking. Ran down the line into the interior fuse panel. Fantastic. Closed the needle valve to prevent it leaking any more for now.
