- Replies 8
- Views 1.3k
Mopar1973Man 2 posts
dripley 2 posts
WiscoRedkneck 2 posts
Bullet 2 posts
Popular Days
Success, truck trailer and I are back home safe. Well all I can say is the only thing that went off without a hitch was getting the hub assembly off, since that was changed with the rotors a few week
No. Mine failed at 350k miles and required a 50 ton press to get them out. The first one I beat out with sledgehammer and took better than 4 hour beating to get the old joint out. The other one I coul
Thanks my assistant/employee is on his way up here with tools to try and pull the axle shaft here in the parking lot I found a local that has a press and he is willing to let us use to try the repair
So both front axle u-joints had about 250,000 on them one blew near civilization got that one fixed didn't think about the other side at the time since I found a shop in the town I was staying at to fix it that day they slipped me in and got it done a half hour before they closed so then the other side blew coming through a mountain pass and now I'm in a hotel with no options for repair and wondering if I could do this in a parking lot with no press. Otherwise for the first time in 15+ years of owning the truck I will have to abandon it until Monday when shops in this town (Boscobel WI) open. Any suggestions? Sorry if I put this in the wrong section
