- Replies 19
- Views 2.8k
int3man 8 posts
Mopar1973Man 6 posts
IBMobile 2 posts
kzimmer 2 posts
I still say switch is bad. Positive 12 volts will not jump a gap in ATF. I can see if the switch was ground and bleed being the entire transmission is ground. But +12V is not going to jump ATF and onl
Again simple. Just unplug the switch and see if the lights go out. If so the switch is bad. Pure and simple. 3157 bulb is not getting enough to light but still running current. LEDs just take much les
Just a thought, but could the trailer connection have a small voltage leak in it? (there is constant power there (from Fuse 8 pdc, along with the reverse lights.) You may want to have som
Hi All,
Well is shouldn't be this hard, but it wants to be. Got up and headed for the airport at 3:30 A.M. Noticed the Truck reverse lights were on. Went back and got the keys and cycled the shifter. No difference. Got back this morning and replaced the Neutral safety switch and Reverse light switch. So reading the linkage adjustment page, I can see nothing wrong. The truck starts in Neutral and Park only. So why are the Back-up lights still on 24 / 7, with a new switch????
I metered the voltage it's a solid 12 volts.
Any suggestions? Only thing that I can think of is the wires have rubbed through? Gremlins
TIA
Michael
Edited by int3man
