Map Sensor
I got some codes that keep coming up P0238,P0234, and P0236 so i decided to remove the map sensor and try to clean it but the map sensor turns but its not unthreading now im not sure how to remove it
  • Replies 4
  • Views 1.6k
Get a mirror back there and verify you don't have a damaged map sensor.
It's just a thread sensor so it either unthreads or it is damaged and will need to be pulled somehow.
