B&W Hidden Goose Neck Hitch Installation
- Replies 7
- Views 2.6k
Popular Days
I wish my turnover ball installation was as simple as drilling a hole for an airbag bracket. I had supports for 5th wheel rails welded to the frame that I had to cut out. Got a nice scar on one of m
I had just the opposite problem, wanted to put on some air bags and turns out that my turnover ball hitch brackets was in the way. My recommendation is to call the hitch place and and talk their tec
If that bracket is leaning in right now then shimming the upper bag bracket out with the with the hitch bracket and flat stock will make it sit straight or out just a hair. I'd be looking at where th
Hi,
I want to install a Model 1394 B&W Hidden Gooseneck Hitch pictured under the bed on my truck.
The truck has aftermarket airbags which I did not install and know nothing about. Former owner had a slide in camper. .
The brackets on top of air bags interfere with me installing the side rails for the Hitch.
There are 2 bolts on each side of each brackets.
My thoughts were to put 1/4 plates between the brackets to bring them out 1/4" so the Hitch side rails will go behind.
Good/Bad idea? Any advice or suggestions would be appreciated.
Thanks.
Leaky
