- Replies 25
- Views 9.1k
Evan 15 posts
Dynamic 8 posts
JAG1 1 post
Dieselfuture 1 post
I like the WOT 1-2 shift at 2900-3000. It won't shift that high unless you go WOT. It's a good benchmark to use for setting the TV cable. There are no "kits" on the market that I can say really addres
Feels good. Barely any change. Maybe a slightly firm 1-2 second shift. 2-3 seems about the same. Lock up a noticable amount firmer. Maybe quicker. Truck seems maybe quicker on the bottom end.
Did you reset the TV stop after you backed it out? What did you set it at? I also would definitely not be running the fluid any higher than what is indicated in the dipstick...just FWIW.
So bought a kit and tore into. Just to see. I did file a thing yeah a thing. And enlarged ports one size up.
Was cool seeing it and seeing what had been done already. A few drill bits bumped up file the thingy.
Got the TV throttle stop on the wrong side of the stop bolt. Luckily backing the bolt out allowed the arm to go by.
I pulled clip on park rod.
Went back together pretty quick.
Sitting here thinking on it.
I've adjusted band per transgo directions snug it with short wrench and back out 2. Pretty sure it went back to where it was.
I love pressure screw were I had it. I was just shy of 150psi at wot before I doubt that will change much.
Getting ready to finish and go home. I've dedicated most of today to the truck. Exhaust and tranny fun
Cross your fingers.
