47re valve body look see
So bought a kit and tore into. Just to see. I did file a thing yeah a thing. And enlarged ports one size up.
Was cool seeing it and seeing what had been done already. A few drill bits bumped up file the thingy.
Got the TV throttle stop on the wrong side of the stop bolt. Luckily backing the bolt out allowed the arm to go by.
I pulled clip on park rod.
Went back together pretty quick.
Sitting here thinking on it.
I've adjusted band per transgo directions snug it with short wrench and back out 2. Pretty sure it went back to where it was.
I love pressure screw were I had it. I was just shy of 150psi at wot before I doubt that will change much.
Getting ready to finish and go home. I've dedicated most of today to the truck. Exhaust and tranny fun
Cross your fingers.
  • Replies 25
  • Views 10.6k
  • I like the WOT 1-2 shift at 2900-3000. It won't shift that high unless you go WOT. It's a good benchmark to use for setting the TV cable. There are no "kits" on the market that I can say really addres
  • Feels good. Barely any change. Maybe a slightly firm 1-2 second shift. 2-3 seems about the same. Lock up a noticable amount firmer. Maybe quicker. Truck seems maybe quicker on the bottom end.
  • Did you reset the TV stop after you backed it out? What did you set it at? I also would definitely not be running the fluid any higher than what is indicated in the dipstick...just FWIW.
To be honest I wasnt aware the 47re could downshift like this
Even before rebuilding it rarely down shifted.
Then after rebuilding I had to drop it into second at slow speeds.
Also to be honest I dont know TV lever specs.
I took the stop turned it until lever contacted the plunger then gave it another half turn or so.
Now it downshifts with engine braking. I like it alot actually now tune si it doesnt down shift as much and early.
I think a zip tie to hold lever and adjust and test drive instead of dropping pan a million times. Learn what does what before turning the screw.
All springs that came in the kit are installed.  I dont believe theres any abnormal wear.
Yes its .106.
I'll readjust TV start with a bit of slack and report. Though I know that makes slack at zero throttle
And keep looking for tvleverspecs
Thank you so much
Ok. I gave TV a fish of slack at wot. This got rid the early down shifting and also smoothed up all shifts. 1-2 s is still quick 2-3 still not as good but seems better than it was.
I like how it's down shift to second. Coast from 30 or so and itl drop to 2nd on it's own. Get on brakes and it drops sooner. Rounding slow corners it drops to second. I used to manually drop it. Now I can just drive.
I've had this truck for 12 or so years maybe 14 and it's never down shifted this well and consistent.
Front band is backed off 2 turns after 72inch lbs. Rear I set by fill and backed off. I cant remember how much. Specs say 3 turns for some reason I dont think I did that much.
It has a harsh 2-3 shift under very light throttle nit nit alo the time. Cruising through town 25mph it now stays in second it's more it harsh shifts when speed is border line. If you know whay I mean.
What do you recomend for both bands, 2-3 orfice size for 150+ pressure?
I'll get the gauge on it and see what pressure is during 2-3 and wot
I'm feeling very good about how its driving. I may order a pan so Ive got a good reason to drop fluid adjust bands and then just drive it.
Also curious. Do your tranny prices include a core.  I kicked around your website. Really like what I saw. Specially the tripe that can get away with stock shafts.
Got my bargain ppe pan on.
Bumped pressure a turn bumped TV stop in a half.
Just for you guys I even filled with atf+4
Dynamics TV cable recommendation helped alot. I still never found a spec on TV stop. It's down shifting perfect and feels very good off idle so I must be close.
Almost grabbed the floor jack. Ppe pan is heavy. I feel good about it and especially since I got it half price.
I'll edit a few pics in
Well funny story so last week did the pan grabbed my inch lb. Wrench to set rear band and front and finally quit messing with my tranny.
Come to find out every tooth is stripped in the tourge wrench. How in the hell did that happen.
Set band by feel fuming. Dont touch front band.
Come to find out Crystal my better half decided to tourge her lug nuts with it. I asked here what she set the wrench to response I dunno. 2 adapters to go from 1/4 to half..
So I walk here to bench, use this big long wrench set it here to about 85-100 I dont really care what. Please reset it to zero when done.
Yesterday dropped the ppe pan used my new wrench, looked at TV stop for alittle bit,  have it set right pushing g on the valve at idle eas curious because cable goes half passed ball at idle. Guess I dont k oi whay the right setting is. I wanna push the valve. If the TV cable had it's way it wouldnt ve pushing the valve at idle or even very low throttle.
I ran the seat back and forth pushing the throttle watching it.  At wot it doesnt quite push the valve all the way in. Maybe 1/16-1/8
I dunno I'm done messing with it.
