- Replies 16
- Views 3k
dually 7 posts
Mopar1973Man 3 posts
Prowelder 2 posts
billy bee 2 posts
When i turn key to on the injection pump runs non stop, the tach will flutter, the fuel relay in the pdc will click,the fass fuel relay will click and the black relay in the cab will also click.What should i do? If i pull all the relays the tach will still bounce.After i remove the key the relay in the cab still clicks.What should i do? Sometimes i have no codes when it does this. If i start the truck when the tach is bouncing i can drive it and it runs fine.The engine light will be on and i can get 8 or so codes. I can clear all of them and it will be fine for a day or so. None of the 8 codes are real.The truck runs fine.shifts fine. It does this with 2 different pcm'sIt does this with 2 different ecm's What should i check ?thank you.
