shutter or hesitation under load
- Replies 7
- Views 2.3k
plyhrdr 3 posts
kzimmer 2 posts
Mopar1973Man 1 post
Dieselfuture 1 post
I will try to disconnect the edge box tomorrow. the box is the correct one for the drive train. I didnt have to modify any of the leads. I dont have a great code reader. but I will run it again and po
P1687 and 1693 probably related. You already explained the 0230. 0336 probably explains your intermittent no-start condition.
hoping someone can help me out. if I go past 25lbs boost accelerating the truck shutters hard and does not enjoy it. will make up to 40ish lbs but it hates it the whole way past 25 lbs. doesnt seem to matter the speed I'm going and the fuel pressure stays constantly between 16psi and 20psi. I just put the injectors in. thought it was because i didnt replac the feed tubes but i did that yesterday and it's still hating life. Please Help!
