- Replies 17
- Views 3.2k
hex0rz 8 posts
Dieselfuture 5 posts
dripley 3 posts
Mopar1973Man 1 post
How does a track bar look, sometimes it can be tricky to check if it's loose. That's what holds axle and frame in check with each other. Also take a look at your control arms. Hate to say but m
Blue top is a vendor here and rebuilds steering boxes. He builds a very good box from all I have read. If you look on top of the steering box you will see the adjustment screw that @Diesel
It almost reads like the truck came with them but they are swapping them out with thicker ones. Mine never had any unless the tire co threw them away when I bought my first set of tires.
After I got my lift pump situation figured out, I started driving the truck to work more since my road was in the middle of mud season.
Upon driving it more regularly, I noticed something that concerned me, ALLOT.
The condition is created mostly when I go around corners. When I apply the brakes, I notice something strange also, but not sure if the two are related.
Upon rounding a curve, if I go a little fast, enough to feel it in the seat of my pants, so to speak, it feels like all the sudden I hit ice. It's a warm sunny day, no ice. But all of the sudden it's like I lose some steering as if I hit ice. I end up correcting about 1/8th to 1/4 turn to stay on course. Scares the crap out of me. I do not get this condition if I'm going slow. I haven't tested low speed sharp turns either.
I do get road wander. Steering wheel has about 1/8th turn slop. I have replaced the front steering components with moog.
Upon braking, the truck will want to pull one direction or the other. Enough that sometimes when I let off the brake, I've overcorrected too much.
Ive dumped quite a bit into the truck to keep it in road worthy condition. But something new has developed and I have refused to let anyone else drive it. Enough to the point ive taken it off the road until I fix the problem.
Upon these findings, I have considered that it was my ball joints. They're still OEM and ive never been able to get grease to them. The zeros were seized up and the ball joints hardened with old grease. As we speak, the truck sits in the driveway in process of ball joint replacements with new moogs.
Before I started tear down, I forgot to check things using the tires. I'll do that after reassembly though. Other findings show that the steering components look tight with no slop using the steering wheel shimmy method.
Something that I did note is that at the pitman arm shaft on the steering box. It looks like it may be leaking. It also looked like the shaft in the steering box had some slop in it. Would there be a way to fix this or do I have to replace the box?
In summary, I know the ball joints need done. But im not 100 percent sure my symptoms match just the ball joints or if I have a synergistic problem with them and possibly the steering box? Or is everything pointing to the box and this is not symptomatic of bad ball joints?
... sure hate chasing my tail!
Edited by hex0rz
