Idling long enough to do pressure test.
- Replies 12
- Views 3.4k
Popular Days
Why, do you think the head gasket is leaking? If not leave it alone. The best way to test if the head gasket is leaking blow by in to the coolant is with a BT-500 combustion leak test kit.
Lifetime coolant. Need find out what the 150K maintenance is, but you’re likely not due for that yet.
I would do this test, and see what it says. The analysis will tell you if you're getting combustion blowby into the coolant, and it will tell you if you need to do any maintenance on the coolant.
Here's situation... coolant been in 4 yrs now, so time to change. Very little miles, maybe 100 miles in last 2 years due to wife cant get in truck because of medical problems. And I cant leave her attended to drive it around to get properly warmed up. And license tabs are also expired now. (Hell of a mess I'm in)
So im thinking about a coolant system test (head gasket leak test) I'll have to idle about 1000 rpm with exhaust brake on. Never since 2005 when we got our 2001 excessively idled. Or should I forget pressure test, and just change coolant? Or idling to get up temps enough for test is OK?
I normally change coolant every 4 yrs.
What would you do?
Thanks for replying.
