Vp44 pump
Hey does anyone know what the little t style valve is below the vp44 pump? 01 24 valve auto...it’s just a little brass t style
  • Replies 9
  • Views 1.7k
    Bad idea...   First off that is not a good place to measure fuel pressure. Second off electric sensors needs a bit of travel room from the snubber. The needle valve is a poor snubber for ele
Bad idea...
First off that is not a good place to measure fuel pressure. Second off electric sensors needs a bit of travel room from the snubber. The needle valve is a poor snubber for electric senders. You need a sinstered metal snubber then at least 5 feet of tubing to the sensor.
I didn't know there was 3rd outlet there for anything.  Beside it being a bad place for the sensor, will that port read supply pressure?
So that’s for a fuel pressure sensor....sorry I’ve had 12 valves my whole life, this is my first 24 and vp pump so I’m pretty dumb about it....so what does it control if I open it or close it?  Just the fuel pressure reading?....doesn’t have a gauge in the cab for that...
