47re lock up issue/mystery switch
- Replies 7
- Views 3.4k
Ronniemx3 4 posts
Dieselfuture 1 post
Silverdodge 1 post
gipperkid 1 post
Strange one I posted recently about not getting lock up when I should, put it down to the quad. I changed the tune slightly that journey TC locked perfect throughout. Next day truck was same as before not locking up at all at times. Fitted a mystery switch. TC will only lock up if I flick the switch and back off the throttle once locked it holds perfectly. To unlock I flick the switch off and have to release the throttle again? Anyone shed any light into this? Oh and the TC will lock on under acceleration if the switch is on and at WOT... I've checked the switch circuit tested good and checked down to pin 7 on the trans. When I rebuilt this box I didn't change the wiring or solenoids so I have ordered these to change as they are original. I done the GM solenoid upgrade that DNJ sell, shift kit, firepunk stage 2 internals with a triple disc. This issue really only started when the quad was installed but it seems even with the box on 0 I still have an issue. What inputs are needed to lock the converter ? Speed sensor or anything like that?
