New Death Wobble Issue – 2001 3500 EX Cab Dually 2WD?
- Replies 9
- Views 5.7k
Junkman 2 posts
Utah Dually 2 posts
Tractorman 2 posts
dave110 1 post
The truck has 82K on the clock – All of a sudden I am experiencing a death wobble around 40 to 50 MPH only under certain conditions. The truck has a Trick Flow tank in the bed. If I put 150 LBS close to the tail gate and hit a small bump it will go into the shakes. If I move the load over the wheels nothing. If I hook my trailer up (10,000 lbs), nothing. My mechanic has replaced a part on the pitman arm and added a steering stabilizer and said the ball joints are fine. I went to a respected alignment shop yesterday and the response was “ Yep that’s a Dodge alright”. I am going to put new tires on the front today since that is a suggested fix but no one seems to be able to tell me for sure they can fix it. Any suggestions on which path I should pursue next? I love this truck and plan to die with it.
