Diff switch from 3.55 to 4.10
So I'm planning on buying a fifthwheel roughly 10,000 lbs I have 35" tires on my truck I would like to keep those for pulling probably best is the switch to 4.10?What's best do the complete axle or just do the gears?I'm running a Fass ddrp with fuel lines 3/8" from tank,installed a bhaf breather,4" exhaust and a smarty s03,turbo is the hy 35,my tranny is the 47re rebuilt triple disc.
  • Replies 86
  • Views 17.4k
  • I really like my 3.55s I wouldn't change to 4.10 even if I had lots of money to throw away.   No clue on what smarty settings. If stock injectors I wouldn't think youd see much heat from any
  • I'm what those but dyno mod feelers. Hmm that didn't sound right
  • Dieselfuture
    Dieselfuture
    Personally I do the axle swap, cheaper easier and you can always keep your old axles in case you want to change back. Unless you're pretty confident in doing gear swap yourself then maybe that's the r
110 psi?  Did it feel like you were rolling on stones for wheels?
I had a tire go on my BMW X5 sport with wide rears.  I wasn't ready to buy a full set yet so I bought a Nankang (China) for cheap brand new and it has worked just fine. But for a full set I'll be looking elsewhere.
Edited by Bullet
8 hours ago, Bullet said:
You know it's really small things like this that we can easily take for granted in the USA...as our choices are almost endless...and not just pertaining to tires.  I greatly appreciate all the freedoms we have and those that made them possible.  Sorry off topic...I'm feeling extra patriotic today.  :USflag:
On topic I would stay away from any tire rated that low.  Kinda gives you an idea of the quality of the tire.  I would look at other tire sizes if it meant that I had more choices.  There's not a tremendous difference in height, if any, between a 285/75/16 and a 305/70/16.  The 305 will be just slightly wider tread...that's all.  They will both go on the same wheel size.  Good luck with your purchase!
Thing is here a American pickup is a minority so while I have lots of choice for a landrover or EU/Japanese there is a lot less for higher load rating tyres, also we're just a tiny island compared to USA so consumer choice will be lower.
As for the K speed rated Cooper I'm baffled on that as it's rated much higher in USA than K and according to the tyre shop owner it has only been K from this year AND is still the same tyre BUT we are still in the EU so it's highly possible that some lazy jobsworth has got the Cooper downrated for EU...... roll on November the 1st when hopefully fingers crossed we kick that rubbish into touch and leave.
I did pick 285 75 and 305 70 for a little more choice and as you say close enough on size... I just want the highest load rating I can find in a good mud ish tyre
9 hours ago, Mopar1973Man said:
The Hankook ATm 245/75 R16 are S speed rating (112 MPH).
I have looked at Hankook but in 285 or 305. 245 is too narrow for my rims and a rim swap here is mortgage the house so deffo not and I like at least 285
And made in China isn't an option I rather wrap rags around the rims
I'm going to drop the truck on the weighbridge at work hopefully before Saturday afternoon and see what the weights are  then add for nose weight of trailer which I will guess over then see what load rating I could use
Edited by wil440
Rubbish indeed!  I think y'all will be getting out by then...hopefully without cutting a deal.  Boris Johnson and Nigel Farage are good friends with Trump and he wants it to happen too.  I love Farage...he's got balls and is super smart...and a cool dude too.  I see good things coming.  Cheers! :cheers:
Roughly 4,400 pound in the front, and 2860 on the rear axle. This is empty truck no cargo. Your truck might be a bit more.
Still only a hope really as it seems like every day some polititian or businessman/woman is trying to stop it, one woman will take to court whatever Prime minister tries to leave with No Deal, today vote in parliment to stop PM suspending parliment to go no deal, think this was last done in the 1600's and the king lost his head..... quite serious here at the moment, I hope we leave N D but I won't be betting on it   it's only the majority vote so it doesn't matter, shame the UK isn't a Democracy
Nigel Farage started a new UK independence party for the EU elections which we had to participate in due to us not leaving in march, this party was 6 weeks old and won over 100 seats in the eu parliment, our 2 main parties won NONE, there was only a handful of others, mainly Greens, still our 2 main parties will not listen to the will of the people, still some try and stop it
Thanks thats usefull to know, so if I went to 5000lbs guess on the rear loaded, fuelled, 2 people and tongue weight I could come down a load range to 3250 to 3500 onstead of 3750
