- Replies 8
- Views 2.2k
Dieselfuture 4 posts
dieseled 2 posts
Mopar1973Man 1 post
dripley 1 post
Awhile back I posted wondering if a VTSS system that I didn't think I have could be causing a no start , and no 25 sec LP run that I was experiencing occasionally , I got no response .
This no start was happening it seemed after the bats were disconnected for a few days while doing other things to the truck , and then it would run again.
I had just replaced the ECM so I wondered if it was causing the problem , but the WTS was working ,LP 2 sec run with key to run worked and the cluster was also , when it ran it was fine , no codes , tach was not misbehaving
So it happened again after the truck had been sitting for a few days - bats where still connected
I started wondering - praying that maybe it was the crank pos sensor - truck is a 99 . Thinking it probably needs a reading from the sensor to activate the LP and somehow have the ECM able to start , from the starter spinning the motor
I did have a po 336 at one point a month ago ,cleared it and nothing more , but I did order a sensor from Genos at that time .
I pulled the sensor , tested the 5 volt and ground , checked for resistance to ECM plug , and for short to ground , put in the crank pos sensor , and all was good , LP 25 sec is back truck starts ,
Now I wonder if this is just coincidence or if that fixed it , I`d like to have faith in this truck again , not wonder if the ECM `s crapping out again
Does the ECM need input from the sensor to run - start , and for LP 25 sec starter bump
I`ve replaced probably 4 crank pos sensors in the life of the truck , usually it just makes the tack erratic , maybe it went out completely this time ?
Sound like the crank pos sensor was the problem?
