- Replies 7
- Views 1.2k
Mopar1973Man 2 posts
KATOOM 2 posts
AH64ID 2 posts
NIsaacs 1 post
Popular Days
Just wanted to update the thread that I have determined that the fan clutch is working perfectly fine. I've been towing in some much hotter weather we've been experiencing these past few days and the
I've read in on quickserve. 180° thermostat is full open at 198° and max allowable 212° 190° thermostat is full open at 207° and max allowable 225° Now you can see why th
Yup that's about right. Being the fan has to sense the heat from the radiator to get the thermostatic coil to twist the clutch to lock up. If the Radiator is shedding heat then the fan will lock. If t
Watch this video and tell me what you think. Take note, there was about 14k behind me pulling a long grade. WOT and the engine temp starting to climb. There is no engine fan roar but as soon as I let up on the throttle you can hear the engine fan come to life and everything cooled right down. It was about 90*F outside too...
I'm wondering if the fan clutch is getting worn out or is there something else going on I'm overlooking.
