- Replies 5
- Views 1.9k
Popular Days
I think a lot of us have the same wire not connected. No one has ever figured out where it goes and why, that I know of. don't worry about it, or ground it if it pleases you.
On my '01 that wire is bolted/grounded to the ABS bracket. https://www.turbodieselregister.com/posts/2418061/
Just taking a little break from my TC Lock problem - which is still under study/investigation.
While digging around,
I found this black wire beneath the ABS module.
It comes out of the same wiring harness as the wires/connector for the ABS.
I rings out to chassis ground. I assume a bolt/screw goes thru the eye, but I see no place
within black wires reach for it to go.
Does anyone know where it's home is please.
I bought truck second hand and it looks like the LEFT Fender might have been replaced.
Thanks.
Leaky
