Was on July 13.  63,6xx miles.   Been a pretty solid truck.  I do make sure that it doesn't go into V4 mode using either my Range AFM delete or M5 around suburbia.
  • Replies 9
  • Views 9.4k
  • dorkweed
    dorkweed
    7500 miles for engine oil is what it says in the owners manual under severe usage.  Direct injection puts a good amount of soot into the oil.   As for the automatic tranny;  I've not changed
Update.
Small milestone.
Just rolled 75,000 on the clock................alot of miles since I posted of couple months ago.
Just 3 days ago, changed the engine oil, sucked out 4.5qts. of ATF and replaced with fresh in the transmission, changed transfer case ATF, and then changed out the differential fluid today.
Pretty solid truck so far.  Won't be 3.5 years of ownership until 1-13-20.
  • 3 months later...
On 4/25/2020 at 8:11 AM, Mopar1973Man said:
Not shabby... Now lets see that Chevy after 300k miles and how its doing.
Doing all I can there Mike.  Keep y'all updated as we roll along.
Engine and tranny are doing fine so far..........as I'm anal about oil changes and pull/pump out 4 quarts of ATF every 15,000 miles and replace with fresh.  Since I've been doing that;  the ATF is still reddish in color when I "suck it out"!!!
Engine I'm changing oil out at 7500 miles religiously.  Oil is still at full mark when I do so.  But remember that I have the module that keeps the engine from going into V4 mode.
Heading to Ocala, FL in 10 days..................another 2500+ round trip..............inside of a week.
Glad she is doing you well.
Are those OEM OCI’s for the trans and engine? They seem awefully short for a modern engine/trans.
As for the automatic tranny;  I've not changed out the filter yet, but I read/hear that they're basically nothing more than a glorified strainer.  Plus it's a PITA to drop the pan to do so.  IIRC;  the manual says to change every 45,000 miles in severe usage.  It's easier just to use my little Amsoil hand pump with a flexible tube attached and run it down the dipstick tube and pull out 4-4.5 quarts and add  fresh.  I do that every OTHER oil change or around 15,000 miles.  Fluid still looks good also..........but looks better after the fresh fluid circulates!!
Cannot argue with 22-23mpg running 70mph in the warm months also.
Took these photos just a few seconds apart about 15 miles from my house while still on the Interstate.  I had filled up in Paducah, KY before crossing back into "The Peoplez Republik of Illinoiz" for this tank of fuel.  Unless it's unavoidable;  I refuse to buy anything in this state any longer. I was on my way home from FL again.  Not too shabby running 70-72mph.
:thumbup2:.. Been wanting to get wifes Equinox out and see how it does on the highway. Shes been getting right at 20 mpg around town.
