AC/Heater fan delay turning on
- Replies 11
- Views 5.8k
GSP7 5 posts
Mopar1973Man 2 posts
IBMobile 2 posts
NIsaacs 1 post
Popular Days
Next time it does it have a volt ohm meter handy. Now, with the key in the on position and the fan speed switch turned to max the dark green wire at the fan motor should have 12+ volts. If no, check
My AC/Heater (fan on)is acting up again.... The fan doesnt go on all the time when I start the truck. I replaced the Fan motor and the speed control dohickey awhile ago, that wasnt the problem
After I drive for awhile 2 - 5 minutes the fan will go on, start blowing air..... I thought it might be the control knob assembly on the dash( on off ac/ heat/ fan speed) but I dont think that's the problem either.
Its been working good for many months , now again in the AM or if I park the truck for a couple hours and start it, not even touching the control knobs , The AC and fan doesnt go on untill I drive a few miles and then it goes on and works / blows cold are fine.
Any Ideas what is causing this? Anyone else have this exact issue and found the fix ?
Edited by GSP7
