Lope tune
This is probably a completely truck rice thing to do, but how would you make a lope tune with Quadzilla? Is it possible?
  • Replies 7
  • Views 6.4k
  • Quadzilla Power
    Quadzilla Power
    @Ravewolf We strongly recommend not making a "lope tune". Although, it can be done utilizing the pump tap parameters it can damage your truck and is not really driveable. Thank you
  • I dont think the code allows for a lope tune anymore without holding throttle at %1.   set tap min and max tps to 0      again...not a good idea.
  • again you may RUIN your vp44 trying to do this, be warned
Not planning on driving with it. More like just throw it on for "show" then load my economy tune to actually drive. Also just curious if it could actually be done..
Ok. Doing this purely for research. No way I'm driving it.
Edited by Me78569
OHHH...ok. Cancel that idea then. Thank you.
Get a set of 7 x 0.010 @ 320 bar injectors you can have natural lope. Mine is mild, only shows as you coast to a stop. Pretty impressive in traffic. Still it idle smooth at at full stop.
