Engine wouldn't cut off then NO BUS
- Replies 10
- Views 2.6k
rburks 4 posts
Mopar1973Man 3 posts
dripley 2 posts
Dieselfuture 1 post
This evening i pulled in driveway, turned key off and got out as always { edge juice cool down timer} but engine never turned off. i came back to truck hit the brake which usually bypasses the edge timer but not this time.. i could not get the engine to stop running. finally i unsnapped the fuse box cover on end of dash and pulled the fuse from edge.. finally got it cut off.. now it won't start, noticed right off that fuel pump not running,, so i cycled the key three time to see if any codes on Odometer,, ALL I GET IS MILAGE BLINKING AND THEN "NO BUSS" I've unplugged the edge but still same thing blinking then NO BUSS
