Loosing Prime / Crossover Tube O-rings
- Replies 28
- Views 8.4k
dripley 8 posts
Octafish 8 posts
pepsi71ocean 7 posts
Mopar1973Man 4 posts
It would start up fine nose up only when i left the block heater plugged in. if I didn't' plug it in, it would loose prime. Even thought it was going on May, I had to leave it plugged in.
Update: Injector shop built me some 150hp's. New BD nozzles (has 8 holes). Popped at 320. So new sticks, O-rings, O-rings for cross over tubes. Downloaded Moparm
The cross over tube o rings wont mix the oil and fuel. The injector o rings will. My last hard start issues were the cross over tube o rings.
I've been loosing prime lately.
* Park nose downhill, starts fine - uphill, hard to start
* Pressurized the return lines from tank filler neck, no fuel leaks visible (did hear a hiss from the top of fuel module - guessing take vent)
* Checked all inbound and return connections, everything is dry (replaced sealing rings/grommets for banjo fitting in back of head and tee 10 months ago)
* Oil level is fine
So at this point I feel like all external fuel lines/connections are sound.
I drive like an old man most of the time.
However the other night, I turned the quad up a little and got on it for a few seconds.
The next couple of days I notice the hard start issue.
Questions:
* Would getting on the throttle blow out a crossover tube or injector O-ring?
* Can you have a faulty O-ring and not get fuel mixing with motor oil?
