- Replies 7
- Views 1.9k
JAG1 2 posts
Dieselfuture 2 posts
Towrigdually 2 posts
Royal Squire 1 post
Popular Days
I used over the leaf spring kit and modified it to go on axle/frame. I don't think kit above was available, if it was I overlooked it. I didn't shave my frame I just made the extension from few pieces
Dieselfuture needs to move out west and I stuff his pockets with money if you do work like that.
Since putting bigger tires on the 3 tons of fun, I don’t have the clearance for over the spring bags, So the hunt began.
I went with firestone F2220 bags, they go inside the frame and and ment for a 2001 dodge 3500 cab and chassis. according to firestone, etrailer, and a few other company’s they shouldn’t work. But they do with minor modification.
ended up elongating the airbag mounting holes by 1/4” and they you can clear the lip on the frame that is bent downward. If you wanted to you could grind out this one spot where the inward nut sits (which is the reason to modify) but to each there own. I didn’t want to cut the frame.
Once up they work great, I will be towing with them this weekend and hopefully will be able to tell the difference between without bags and with.
Hope this helps someone if they have larger tires on a dually also.
