I have an annoying issue with my 98. It over fuels bad at a certain tiny spot in the throttle but only on takeoff. Truck is a 5 speed with 215 pump with a home cut 100 plate. I have the plate slid halfway forward and if I back the smoke screw out anymore it will fall off. The star wheel has been adjusted slightly and the housing itself is about centered. Truck runs really clean up top and down low, except for this small spot in the throttle on take off. I usually ease into the throttle and miss the spot but once or twice a week ill accidentally find it and it belches thick black smoke. I have a needle valve at the afc on the boost reference line. I also have PDD Bosch 5x.012 injectors set at 305 bar and like I said before, truck runs real good and clean every other part of driving. Ill see if I can get a couple videos this weekend.
Low boost overfueling
- Replies 6
- Views 3.4k
98whitelightnin 3 posts
Mopar1973Man 1 post
Dieselfuture 1 post
Cowboy 1 post
