- Replies 16
- Views 2.3k
Mrangry 8 posts
dripley 6 posts
Mopar1973Man 1 post
Dieselfuture 1 post
Been fighting with a really strange issue. I used to have strange power issues and dead pedal and the tach would bounce around and die every now and again. I have since diagnosed the dead pedal back to a faulty factory apps and replaced that with a timbo unit. That actually seemed to fix almost all the issues. Maybe 2 weeks after all that, I went to the dealer and finally had high idle programmed into the truck. The high idle has not kicked on at all, and yes it is cold enough, and I'm sure the sensors are reading correctly, I'm going to double check tomorrow morning. But recently, within the past 3 days, I've had an issue where the alternator will stop charging for a couple seconds to a minute, then randomly start working again. It's weird to me that it throws the cel for a split second and turns it off, you would think it would leave it on after it sets. One of the times it stopped charging, it almost seemed as the truck was in limp mode, I had no power. And as seen, sometimes the water temp acts erratically with it.
