Window auto function quit working
- Replies 7
- Views 2.4k
IBMobile 2 posts
Sycostang67 2 posts
Dieselfuture 1 post
wil440 1 post
I think you need a new switch, read this. OPERATION The power window switch for the driver side front door has an Auto label on it. This switch has a second detent position beyond the nor
My 98.5 had both window switches not working when I got it, It hasn't got auto down which for me is ok but I did fix both my switches, IIRC I managed to cut a small strip off of a nail filing board an
I've done that on the 2000 and older Volvo window switches. I used strips of 400 grit paper to clean the carbon off the contacts but the coating on them had gone bad so the switches would fail again
The auto down function for my driver side window quit working today. It still rolls down if I hold the switch though. Is there a relay I can check or is it the switch that goes bad? I know it's trivial, but I like hitting the auto function so the window can roll down while I put my seat belt on. It's the little things.
