- Replies 8
- Views 1.7k
lrhull 3 posts
Mopar1973Man 2 posts
JAG1 1 post
hdpwipmonkey 1 post
I'll try to make a long story short. I had the clutch changed a few weeks ago. Because of where I mounted the high idle switch down by the gear shifter I removed it. It's one of the first I switches I got it from DAP. I previously already changed the open wire in the harness because it started having problems. So back to this problem, I put the switch back in and the other day the IAT temps seemed weird on my scan guage 2 so I removed the switch to check it all out and make sure all connections were good. While doing this the power wire going to the switch for the indicator light came off. Me being the idiot I aim, I solder it back to the wires coming from the resistors. I checked everything else and it all seemed good. I put the switch back in, turn on the key, but did not start, check engine light came on water in fuel came on. So I took the switch out and realized what I did. I plugged everything back in without the switch, cleared the codes and started it, the water in fuel light is still on and codes po380 and 382 are coming up and I don't think my grid heater is coming on. So what did I do by sending power through the harness to the IAT water temp sensor etc? Where do I even start?
