rear output shaft seal (pissing me off)
- Replies 8
- Views 3.2k
elshadow001 3 posts
ISX 2 posts
guesswho512 1 post
AH64ID 1 post
Awhile back I noticed some atf on the bottom of my truck just above the front u joint of the rear driveshaft. Anyways last weekend I replaced the output shaft seal by removing the rear driveline, tried to pry the seal out to no avail so I removed the extention and smacked it out from the front end, no biggie. Installed new seal, then the driveline, filled up the transfer case and called it good. I cleaned up the previuosly leaked fluid from the underbody. Now there is fresh fluid there so I am sure it is still leaking. The sliding yoke did not feel like it had any abrasions where it rides on the seal ?? My t case says its a model 242 but the dude at the parts house said the one I need was for a 241?? I measured them with a caliper and it seemed to be the one. Why is it still leaking ??:banghead:
