Want a little more power
Looking to get a little more power, probably all I need is a little more boost. Anyone know anything about Turbosmart wastegates? Another option was a boost fooler but heard mixed reviews as how much they actually do.  Also was looking at upgrading Turbo, Borg Warner makes a drop in K27 that it says has better low/mid range response. Not sure I want to upgrade to more performance electronics like Quadzilla or Edge. Any suggestions?
  • Replies 21
  • Views 7.5k
  • dieselautopower
    dieselautopower
    K27 is 60mm compressor, but it is shorter and smaller and moves LESS air than the s300G 57mm.  K27 is similar to 35/40 hybrid, and max 75-100HP injector with an adrenaline.   57mm s300GXE is
  • dieselautopower
    dieselautopower
    Edge EZ does boost fooling so adding a Qudzilla fooler will not get you any gains.  A boost elbow would help a little.   More fuel and custom tuning with an adrenaline would be the next upgr
  • You're using an Edge EZ and RV275 like I have.  I'm  using an adjustable boost controller and have it turned up to 30PSI of boost.   I got out of China for $5.  Some other members ordered them but I t
I agree. Stock 4th gens would cower till the stick center seat area needs to be grabbed.
