Electrical Gremlins (CCD Data Bus Issues)
- Replies 7
- Views 2.9k
NorthernDodge 2 posts
hdpwipmonkey 2 posts
Haggar 1 post
Tractorman 1 post
Might as well get the embarrassing part out of the way first, I tried to take a shortcut while wiring up my new radio and majorly messed up. While hooking up the steering wheel control adaptor I grounded what I assumed was just one of the two wires going to the steering wheel buttons. You know what they say about assumptions. What I actually grounded was the positive side of the CCD circuit. When I turned the key on I got the no bus message on the odometer along with the other symptoms that come with that, but the truck did start. Naturally I put all of the wiring back the way it was, but now the truck only cranks but never fires. So I can either have a running truck with no gauges, no cruise, no overhead console, etc. or I can have working gauges but a non-running truck. I'm hoping someone here knows what I possibly could have damaged by grounding the + CCD wire that would cause the truck to not fire.
On the plus side the radio works well.
