1999 24 valve high idle and bucking at highway speeds
So I have a 1999 24 valve all stock no tuner.. and I can start the truck and it fired right up and it will idle around 800 or so rpm and when I hit the throttle it will idle at 1100 and at highway speeds the truck will buck and if I let off it’s fine until I get on the throttle again I just replaced tps/apps and set the correct voltage and done the pedal thing the map and iat sensor are showing they work on my scan tool but no codes I’ve only owned the truck for a couple weeks and the vp44 has a sticker on it and it looks brand new all my ground are good but idk what to do.....
  • Replies 31
  • Views 6.9k
  • Didn't say Jack about setting any voltage on Timbo. The phrase "There is no voltage to check" could lead people astray. If your not checking voltage, why do you need a voltmeter? So do
  • It sounds to me that you are describing the normal cycling operation of the intake manifold heaters .  Combined, the two intake manifold heaters draw about 200 amps - that is why your are seeing the d
is there more than one coolant temp sensor the only one  have found is by were the top rad hose goes into the the cylinder head.
So i got a mutimeter and put it on the battery and its dropping voltage at idle i then went and measure the alternator output and it was consistent so im losing voltage somewere
 Check the cable that goes from the alternator to the PDC where the 140 amp fuse and from the other side of the fuse and the battery for high resistance or bad connection..
Has the W-T Mod been done?  See below.
As to my knowledge no but I read it a little and it talks about the torque converter shuttering problem and my truck is a 5 speed but I will check that spice and see what it looks like and follow the wires
at idle my voltage drops sometimes and you can hear a load drag the engine down a little and the lights on the dash and headlights dim i have a feeling this and my bucking have something to do with eachother. After a few seconds of the "load" it goes back to normal and it does it repeatedly the guage on the dash will go down to 11 or so volts then come to a little after 14 volts ive put a multimeter on the alternator while its idleing and no jumps or hiccups with the voltage coming out of the alternator.
These trucks control units are very susceptible to not only poor grounds, weak connections at the battery, bad batteries, corrosion in the connectors but AC voltage from a bad alternator diodes.  If the AC voltage is high enough, >0.03VAC, It will cause not only automatic overdrive problems but other drivability problems to the point of ECM/PCM failure.  I strongly suggest you test for AC voltage with a quality volt meter, like a FLUKE multimeter, and read over that Ground Reference article.
Edited by IBMobile
It sounds to me that you are describing the normal cycling operation of the intake manifold heaters .  Combined, the two intake manifold heaters draw about 200 amps - that is why your are seeing the drop to 11 volts while idling.  When the heaters cycle off, the voltage returns to around 14 volts.  The heaters will continue to cycle until the engine coolant temperature rises to a specific value or when the truck has been driven over a specific speed - approximately 25 mph.
- John
Ok thanks for clarifying that so now I’m just on the hunt for a bad ground correct?
Ok so I unhooked the intake heaters on the drivers side battery and no more voltage drop but it still high idles but the bucking has completely stopped until I get to about 80 mph/2500 rpm
Edited by 24vgarrett
So now my truck wants to idle at 2200 rpms all the time and won’t stop no matter what I do
