Timing regarding cetane number
- Replies 55
- Views 10.2k
Southpole560 15 posts
Mopar1973Man 14 posts
dripley 10 posts
LorenS 5 posts
@Southpole560 @dripley the plug is NOT 1/4" it is a metric straight thread that seals with an o ring. I hsd a hard time finding the right adapter to go to 1/8" pipe and posted the thread size and Park
Higher the cetane the more the retarding you would give. Lower the cetane the more advancement you would give. Higher the cetane the lower the BTU's. Lower the c
Engine load and engine oil temperature. As timing advances the engine oil temperature will rise. Then when you retard it will fall. I'm aiming for lower engine oil temperature and low eng
So I just found out that the local supplier here in Oregon (SeQuential), that supplies fuel to the Shell station I usually go to, has a cetane rating of 55.3 for their B100. They cut it with regular #2 diesel to make it B20. The cetane rating should then be about 50 for the B20. All the research that I've done states that B20 should be right about there. My question is, what timing would be the best for this 50 cetane fuel? I normally drive at 60-65 and my rpms are ~1550-1675. Should I be around 16* cruise timing for max fuel economy with this fuel or is that too low/high?
