- Replies 8
- Views 2.3k
Dave Dave 3 posts
dripley 2 posts
Haggar 1 post
Tractorman 1 post
Hi all. I am new to this group. Thanks in advance for any help. The truck is an 2001 Ram 3500 6 speed manual 5.9L 24 valve cummins, totally stock except for a Fass lift pump. The power is down about 60% sometimes. It feels like a half dead pedal.The power is fine or down 60%, never in between. The problem started occurring once a week, then 3 times a week, then twice a day, then most of the time. Now it is down on power almost all the time. This was over about a six month period. I can, sometimes, achieve full power if I rev the engine past 2500 RPM. No difference hot or cold. No exhaust smoke. No codes stored, using the key on three times technique to check. 14PSI at the injection pump inlet, 12 PSI at wide open throttle. First I replaced the TPS (apps) and fuel filter. No difference. Then I replaced the injection pump (vp44) with a rebuilt one that I purchased from Valley Fuel Injection. That made no difference. Then I was really scratching my head. I have a parts truck that was running 2 years ago so I swapped out more parts. Those include Map sensor, cam sensor, engine ECM. Still no difference at all. The problem did not change AT ALL with any of the above parts. What am I not seeing? Any help would be greatly appreciated.
Edited by Dave Dave
