- Replies 46
- Views 5.2k
What "shift kit" was used? What is the stall speed of the torque converter? VP44 trucks are notorious for not being able to fuel the engine quickly enough to catch the load of a converter
I've never heard of Freeman Creek Transmission in Orofino, and I'm only a couple of hours from there. Oh well, I don't know everyone. Pressure is not going to stall the truck when you put
I do believe if the VP was starved of fuel enough that putting it into gear killed the engine that the VP would have already crapped the bed. The VP is heavily reliant on fuel for lubrication and cool
Hi all, I have what I believe is a 47re trans. question, so I'm a new owner of this truck and I'm admitting I'm more than a little nieve when it comes to transmissions. Anyhow, the truck seems to run pretty good and has a "built" trans. as in shift kit, beefed up torque conv. etc.. The prior owner said you have to kinda power brake it when it's cold or it dies when shifted into gear, said it had something to do with stall or? Well sure enough every time it sits overnight I have to go through the same ritual and then the rest of the day it does fine, idles fine, @750ish? Runs great,shifts great I've tried letting it sit and warm up for quite a while, but no, same thing like torque conv. locked up until it's revved a little in gear. I've tried letting it sit and warm up in neutral, tried pushing t.c.lock up button, no and nope? After going through the ritual I can shift into gear normally without insident. I have receipt for trans work so I decided to give them a call to see if this was in fact "normal" the guy I spoke with said it wasn't and never herd of such a thing! Maybe he's never herd of google? Because I'm coming up with page after page of people asking the same exact question! Some say it's normal some don't, really can't get any consistent answers. The trans shop guy said they don't mess with the stall and told me that they'd have to look at it, but it's like 300mi away, so....
I really don't want to take to tranny shop if I don't have to, but? Any educated ideas would be greatly appreciated! Thanks!!
