No key on power to fuel pump
- Replies 11
- Views 3k
Todd w 4 posts
dripley 3 posts
01cummins4ever 1 post
NorCalAndrew 1 post
Popular Days
If I’m reading this right , Sounds like your raptor 100 is trying to pull fuel out of the in tank pump, I believe the raptor installation call for removing the in tank pump if it had one. That could
It does sound like you are running 2 fuel pumps at once. I had this set up many years ago. An in tank pump and a booster pump on the frame rails. The intank pump ran off of the stock wiring harness. T
I have a 99 dodge 2500 with the 5.9 Cummins
I recently had the return line on the stock fuel pump rust off so I replaced it with a precision fuel pump part number 30060 from oriellys And ever since I installed that pump I have no power to my fuel pump. I looked on the oriellys website and it said the pump is for trucks converted to an intank pump and I'm still running a raptor 100gph transfer pump and I'm wondering if that would cause it to not have to power to my fuel pump? The truck will still start and idle off of my transfer pump but I only see 5 pounds on initial start up then drops to 1 pounds of fuel pressure after idling for about 10 seconds.
