Coolant behind harmonic balancer
- Replies 7
- Views 2.2k
Royal Squire 2 posts
jtrakel 2 posts
Blueox01 1 post
Dieselfuture 1 post
Popular Days
I thought I had head gasket leaking but turned out to be water pump. Rent a cooling system pressure reset and pressure up cooling system and should be easy to find.
Water pump, would be my first look at.
Evening first time poster! I've been lurking this forum for a bit now with the anticipation of purchasing a new to me 2001 with 160,xxx, new to the 5.9 but have owned two 6.7's in the past. Today while looking under the rig it appears to be coolant behind the harmonic balancer. I went for the water pump and thermostat housing first but no joy on any coolant leakage. Besides the radiator hoses where else should I look for a possible leak OR what could fluid being in that spot indicate? Also of note after a short drive I crawled under and saw some drops on the steering linkage and some drips on the concrete.
The seller recently worked on the oil pan gasket and needless to say I have an OEM gasket on the way right now as it looks like a 2 year old smothered RTV everywhere. Truck runs strong but has a lot of random quirks and boxes (BD TQloc and a very old school looking exhaust brake and another box I'll have to post a photo of for identification help). I'll be removing all of these "mysterious" components so I can start fresh with the W-T ground mod/PCM and ECM grounding. I also noticed a ton of oil everywhere in the engine bay and my research pointed to the crank case puke bottle so I'll be doing Mopar1872Man mod this week
Ideally my goal is to get the rig back to stock(ish) electrically and do all the supporting mods to clean up and AC noise issues and move on from there. Thanks for reading my novel, cheers!
