- Replies 27
- Views 12.5k
That is the data link connector. My comp is plugged into it. Ismthat the Map sensor I see connected right beside it? Or is that the IAT? My 02 came oe with with a MAP they quit making. Whe
Electrical gremlins are no fun. Mine were on a mostly stock wiring other than what I have added over the years. If the PO did alot of mods it can make solving problems interesting. The gremlins I went
Looking to identify where this plug is supposed to go the wire colors are Yellow/Blue, Yellow/Green, Black/White. It's located next to the ECM on the right side of the motor as you face the truck. just above the engine mounted fuel pump.
I unplugged it from a pigtail system which is in the attached photos. There are zero markings as to what this box is/does, the small tag on the wire loom is not legible the only thing I can pick out on it is "4-02tdw". Any help would be appreciated, I reconnected the cannot plug to the left of the one in question as well that's depicted in the first photo. This was also connected to the system in box in question.
Edited by jtrakel
