- Replies 52
- Views 5.7k
Clyde 23 posts
dripley 15 posts
wil440 7 posts
Mopar1973Man 4 posts
No. It takes everything I got to just pull the shaft over the wastegate arm. It heavily sprung. No. P0237 code is a lo volt code for the MAP sensor and has zero to do with the was
I agree with Mike. You can put air pressure to the waste gate to move it.
I use straight pins for back probing connectors. You can get them with plastic balls on the blunt end so there is no metsl to metal contact with each other. They are a lot easier to get into the conne
Just put in a new fass lift pump and vp44.
have no power.
Wont rev above 2250 RPM in overdrive
will rev to 3000 RPM with out overdrive.
really slow to get up to speed .
Not a lot of cash left to throw at the old girl.
heart broken to see her sittin there
