Turbo/Injector upgrade (Heavy Towing) Shoutout to Me78569
Looking for injector/turbo upgrade for strictly towing. End goal is compounds but, id rather keep 5k into rebuilding the 200k mile engine if it needs it. I just purchased a 40' 2 car trailer that i use for my hobby demo derby and i will make multiple trips to New York to drop southern clean cars from my state of Florida to my brother. Ive upgraded a bunch on the truck since i bought it not even 9 months ago. I used Me78569 stock injector towing tune and it was great but was getting into 1250 on the egt temp gauge and Florida is super flat up north with the huge hills and grades i think turbo will be a issue. Most research ive done says a 62/68/12 is what i need with 100+ hp injectors but want more opinions. Truck Is a 2001 3500 dually, NV5600, New Blue Chip vp44 , Quadzilla adrenaline, ARP head studs, South Bend dual disc organic/ceramic clutch, 5 inch mbrp straight exhaust Air dog 165 Lift pump, beans diesel sump, etc. First pic was last weekend with a buddys  trailer second pic is my new 40' that i need to pick up whenever with corona **** is over. Thanks for all input.spacer.pngspacer.png
Edited by 1369x
  • Replies 46
  • Views 15.4k
  • dieselautopower
    dieselautopower
    HE351 would have to be modifed to address the small turbine wheel and housing to = the flow of the 57GXE.  Call in when you are ready and state you are a MOPAR1973MAN forum member and we will get you
  • Forgot hp/tq goals... was looking for 500hp via compounds and 1000tq and just a quick spooling hauler idc about having a big **** contest with the local high schoolers squatted 5 tree Tahoe bouncing o
    I'm running 7 x 0.010 injectors (150 HP), HX35/40 Hybrid (60/60/12), Quadzilla Tuner.   I've towed plenty of heavy loads. Right now I'm getting prepped for making a trip sometime in the futu
the 57/65/14 can support 500HP, but would be hot.  450HP is more reasonable.  The 12cm improves spool, but decreases peak HP.  You are at lower elevation and have stock size tires or close to it so spool should not be too hard with either a 57mm or 62mm.  The extra turbo is a nice addtion for EGt control and keeping boost up so the engine is responsive.
yea that would be my choice lol.   but you loose ~100 hp worth of air with the 57 vs 62
15 hours ago, Me78569 said:
Your ultimate power goal dictates your path.  A single at 500 hp can still tow very nice.
Exactly.
13 hours ago, Me78569 said:
I don't like towing with wiretap personally.  I would leave it on lvl3 towing.
A killer tow setup with be 7 x .010's and that 57.   66lb/min is a good 400 hp worth of towing air.  that is a CONSIDERABLE upgrade over what you have now.
All diesel guys love the idea of 500+ hp, but more often than not a 350 hp setup is more than enough to make you smile. We all suffer from the hp drive.
Not to downplay the 62/68/12 setup as that is a tried and true 500 hp DD / tow setup but I would personally be looking at the 57 if I was towing a lot and mulling over the idea of twins down the road.
either choice will work, the 62 will have more power up top the 57 will outspool the 62.   if the truck is more of a toy then 62 if it is more of a work horse then 57 :2cents:
x100.
I just went through the same quest as you OP but I have no desire to run compounds.   I built a HX40 hybrid that is a billet wheel 60/64/12 for about $600 all in.  The turbo is amazing and does the job perfectly IMO in the towing application.
I just finished a 7 hour round trip towing a 14k 5th wheel and the turbo performed fantastic.
Agree with above... towing above level 3 (wire tap)  is kind of crappy because wire tap is not conrolled very well and tends to be abrupt/jerky.
The one mistake i made was buying 7x0085 injectors as an early mod when i bought this truck.  I should have gone 7x10s from the start and my truck would now be done being modded.
5 hours ago, dieselautopower said:
True,  some peak HP loss.  It depends on the primary and secondary goals of use for the truck.
 Primary is Daily Driver secondary is all towing. Truck doesnt get raced I dont think I've went past 3000 rpm since I've owned it the 5 inch exhaust and drone gets loud at 2800 lol. Here in Florida I'm 49 feet of elevation , where I tow to in New York 3-4 times a year is 1400 feet elevation if that helps any. Also dont plan on any weight over 26000 combined I dont want to gave to get a cdl for a hobby lol.
Edited by 1369x
I drive it daily but 90 percent of a time theres a trailer attached to it.
both turbos will do the job,  would you prefer faster spool at the cost of 100 hp worth of air or do you want that extra air with a little slower spooling turbo?
Edited by Me78569
With the 62 I'd have to look at some valvetrain upgrades? Pushrod,valve springs. You promote the he351 turbo pretty good seems like the GXE 57 is a high dollar one of those which if Its a direct replacement seems to be the better option for me. Only thing that sticks out to me with the 62 is the 500hp and that would be the easier turbo to get rid of if I didnt like it. The faster spooling will help me on the hills up north since it will spool faster. I doubt I'll be in 6th gear going 75 up the hills but 60 in 5th seems more like a thing. The 57 GXE will most likely be the one I go with.
If you arent spinning high rpms and dont have an exhaust brake then no valvetrain stuff is needed.  The 62 can flow enough air to get into the area of springs being a good idea, but again not really %100 needed.
HE351 would have to be modifed to address the small turbine wheel and housing to = the flow of the 57GXE.  Call in when you are ready and state you are a MOPAR1973MAN forum member and we will get you a discount.  Happy to support the forum and its members!
If that's the case I'll probably go 62 dont really see the concern for exhaust brake unless I'm up north with the grades but plan on upgrading to 3rd gen brakes if that's a option for my truck. I baby the truck for rpms always shift between 25-2800 Thanks for all the help!
Edited by 1369x
I wouldn't go any smaller than a 62 unless you are definitely going compounds.  The 62 will tow very well (especially with the manual trans) and make the kinda of power you're talking about.  Won't spool quite as fast as a 57 but won't run out of guts as fast either.  The spool difference is much closer together than the power difference is.  My 62 spools almost exactly like the hy35 I replaced...and way more air/power in comparison.
Has anyone had experience with Fenley precision inductions cam across there Facebook page for a hx 35 60/67/12 how would this compare to a 62 besides the price difference?
Id do the sxe.  The hx turbo was designed 20+ years ago.
Modified HX35 and HE351 have their place, but its not =  an s300.  bearings are smaller, compressor housing is small.  It all depends on the application.  Always keep in mind the time to rebuild, and the loss of a core or good turbo to make the hybrid.  If one is in love with a project and it fits thier needs then go for it.  The SXE is such a good value.  Custom $2000 dollar turbos from a few years ago wish they could have been SXE turbos.
When I call who do I ask for? Or does it matter?
Call in and speak with any of the sales/techs, Fred, Matt, Lenny, Nathan, Mitch.  Reference this thread here on the forum.  We are open 7AM-7PM MST on weekdays (friday we close at 4:30PM)
62 65 14 turned my truck into a towing machine.
I'll agree 350horse tows well and runs cool. I regularly tow 18k plus with cool temps. It definitely moves some air.
I think it spools fast. Fast enough to surprise many here.
In 5 years itl be mandatory to have 62 almost like it seems the truck wont run without a quad now. Lol
Edited by Evan
