Turbo/Injector upgrade (Heavy Towing) Shoutout to Me78569
- Replies 46
- Views 20.2k
1369x 15 posts
Me78569 12 posts
dieselautopower 10 posts
Bullet 4 posts
HE351 would have to be modifed to address the small turbine wheel and housing to = the flow of the 57GXE. Call in when you are ready and state you are a MOPAR1973MAN forum member and we will get you
Forgot hp/tq goals... was looking for 500hp via compounds and 1000tq and just a quick spooling hauler idc about having a big **** contest with the local high schoolers squatted 5 tree Tahoe bouncing o
I'm running 7 x 0.010 injectors (150 HP), HX35/40 Hybrid (60/60/12), Quadzilla Tuner. I've towed plenty of heavy loads. Right now I'm getting prepped for making a trip sometime in the futu
Looking for injector/turbo upgrade for strictly towing. End goal is compounds but, id rather keep 5k into rebuilding the 200k mile engine if it needs it. I just purchased a 40' 2 car trailer that i use for my hobby demo derby and i will make multiple trips to New York to drop southern clean cars from my state of Florida to my brother. Ive upgraded a bunch on the truck since i bought it not even 9 months ago. I used Me78569 stock injector towing tune and it was great but was getting into 1250 on the egt temp gauge and Florida is super flat up north with the huge hills and grades i think turbo will be a issue. Most research ive done says a 62/68/12 is what i need with 100+ hp injectors but want more opinions. Truck Is a 2001 3500 dually, NV5600, New Blue Chip vp44 , Quadzilla adrenaline, ARP head studs, South Bend dual disc organic/ceramic clutch, 5 inch mbrp straight exhaust Air dog 165 Lift pump, beans diesel sump, etc. First pic was last weekend with a buddys trailer second pic is my new 40' that i need to pick up whenever with corona **** is over. Thanks for all input.
Edited by 1369x
