Quadzilla adrenaline custom tuneing can bus fueling
Okay I picked up some 7/12 injectors with large feed body’s and vco nozzles and was wondering what I need to set my can bus fueling to  get these to fuel right it’s fueling  way to hard
Edited by Project_blackgold24v
  • Replies 7
  • Views 2.3k
Have you read through the Quadzilla tuning procedure? Are you running with the wiretap on?
Start at about 80% and work your way up.
Also I would have to know several other factors.
  • Tires size
  • Axle ratio
  • Transmission
  • Injector pop pressure
  • Turbo
Yeah I have ran it on wire tap and with out and still fueling hard  it’s drivable on 0 bit of you go to get in it it covers the hole road behind me and  I made a tune with it wire tap where it don’t come on to about 15 psi of boost and start the canbus fueling at like 80
  • Tires size
  • Axle ratio
  • Transmission
  • Turbo
Need this information to help you...
Did you follow the directions in section 2 for how to get started?   It lays out how to find your starting %
Injectors are 3000 pop and 35 inch tire  has a Borg364.5/73/14cm  and has a billet duel disc converter stage 2 clutches had shafts   it’s a sport I think the gear are 3.54 and
Oh my this is going be impossible to clean up.
7 hours ago, Project_blackgold24v said:
35 inch tire
Tires being 35 inch tires your final ratio is too low at 3.21:1. This is going to require lots of fuel to get turning. Optimal you would need 4.10 gear to fix this. Like myself I swapped out to 30" tires this raise the final ratio to 3.69:1, more torque to the ground, extremely low EGT's, no smoke at all. 650*F at 80 MPH at 2,450 RPM in 5th gear.
What size injectors?  (Found it ( 7x 0.012) injectors in the first post)
3,000 pop is too low. Stock starts at 4,500 PSI or 310 bar. I'm even using 320 bar (4,641 PSI).
Borg364.5/73/14cm
Turbo in my opinion is too big. Spools too late. Hence your smoke, you can't spool that big turbo quick enough quick enough. Optimally 62/68/12 will support 150 HP injectors up to 200 HP injectors. I'm even running HX35/40 hybrid (60/60/12) with 150 HP (7 x 0.010) @ 320 bar which spools extremely fast and giving me just at 47 to 49 PSI of boost.
Still think the turbo is too big.
