- Replies 16
- Views 3.3k
jtrakel 6 posts
Mopar1973Man 4 posts
dripley 4 posts
CAMG3X 2 posts
Popular Days
ZERO. I placed the stud in the hole. Then using a 2x6 lifting from the floor up to the cowl using a floor jack I slowly jacked the cab up nearly an 1/2 inch and the stud fell in the hole by itself. Th
Afternoon while replacing my head studs today to some ARPs I noticed some water in the head stud wells. It doesn't look like coolant as it's clear vs green and hardly mixed with oil. Of the 8 studs I've done two of them had this water in the hole. There is no real smell and is does have a slight viscosity but dries up like water would vs that "oily" feeling from coolant or oil. See the video of me using a clear straw to extract the liquid.
I've read that our studs do not go into any water jackets, I've also read about finding condensation/some water while doing head studs but this seems a little much. The obvious answer is a head gasket but I'm not seeing any other signs. Smoke for exhaust, coolant in oil, and I got a oil test done about 1 1/2month ago with no indications of a pending head gasket. Has anyone done a head gasket at home, any recommendations do/don'ts if I go down this path?
