- Replies 4
- Views 1.7k
Mopar1973Man 1 post
dripley 1 post
Alexio Auditore 1 post
Epr2x10 1 post
What’s up guys? I recently had some issues with my truck which caused me to pull codes on it. When I did that I read the “diagnosis” on 2 different handheld OBDII scanner. Both of them were showing around 13% on the apps or tps. I have tried to mess with it to recalibrate it before but when I do mess with it, it throws a code and the CEL comes on. I have noticed that I have to pushed the peddle further than I should to get the truck to accelerate. It is an aftermarket APPS that is on the truck. Back when I bought the truck I assumed it would solve my ground/ lock/unlock issue. Then I realize that had nothing to do with it and never switched it back to the factory one because there wasn’t anything wrong with it. My ideas on where to begin to get better throttle response And/or recalibrate it so it isn’t showing anything when I’m not on the peddle? Thanks
Chris
