- Replies 9
- Views 4k
Vinster_Beta 4 posts
dripley 2 posts
Haggar 2 posts
wil440 1 post
I have a 2001 Dodge 2500 5.9l that is stock other than a Predator mechanical fuel pump that I have recently put on. I have had the issue even before I've done any work to the truck of there being brief second of no power and then returning like nothing happened. I will be driving normal (Smooth accelerations) and every once in a while the truck will loose power and go back to normal in a matter of a second. I've always thought it was a problem with the stock lift pump on the side of the motor so i recently replaced it with a predator lift pump and haven't seen it run below 14psi. But even after I did so it still does this intermittent loss of power issue. It can vary from every other ride to weeks between cycles. I have no codes or lights on the dash and am starting to think it might be the VP disagreeing with me and wanting to quit. I have no tunes or anything going on with it and I tried resetting the APPS and nothing has changed it. Only other thing I could think of is air or suds making its way to the Injection pump every so often. Anyone have any thoughts?
