Hello everybody I appreciate any advice. I just purchased a 2001 Dodge 2500 5.9L Cummings, This truck only has 95,000 miles on it in great condition but it hasn’t been driven very much in the last five years I am going to change oil, oil filter,  fuel filter anything else you recommend doing to it.  Also it gave me a  P0234 code Overboost. When I was on the freeway getting on it,  cleared the code it came back a few days later on the freeway again recommendations
thanks zev
  • Replies 12
  • Views 2.5k
  • CUMMINSDIESELPWR
    CUMMINSDIESELPWR
    1. fuel pressure gauge 2. exhaust temp gauge 3. aftermarket lift pump ASAP, either electric or mechanical 4. pcv vent mod
thanks zev
Can you give us a bit more info on the truck such as any modifications that have done to it, like tuners or injectors or such? ,The 234 code could be quite simple with some more info.
As far as fluids, I would change them all. Start fresh with everything.
 As far as I can tell the only thing aftermarket is a E brake system by Jacobs and MBRP  performance exhaust stacks besides that the truck is stock. It’s only had 2500 miles put on it in the last five years.
6 speed manual transmission
Edited by Zev f
Original owner passed away, purchased truck from his family
We have a list of trouble codes in the articles section under 2nd gen 24v. Sorry but I cant link it. Just lookup the code and will have diagnostics for trouble shooting. I would think since the truck has sat so much the wastegate or actuator might just be stiff from sitting and holding closed to long. The stock should open around 18 to 20 psi. If the ECM sees 20+ psi to long it will set the code. If any part of linkage is stiff it might not be opening in time to stop that. You could oil the linkage and put some compressed air to it to work open some and see if that helps. The turbo is capable of well over the 20 psi to set the code.
I would also take heed of what @CUMMINSDIESELPWR recomends. The stock fuel systems are not very robust for these trucks. What system to add depends on what you have in mind to do with the truck. And install a fuel pressure gauge. It is the safest way to know that your fuel system is operating properly.
The crankcase vent on the front of block will puke oil out on the radiator and clog it. There is an article about that very mod.
The list can go on and on. It is all dependant on what you want to do with the truck. It sounds like a gem to work with. Do you mind telling us what you paid for it? Just asking.
Thank you for your advice, this truck is a gem it is in amazing condition interior looks like a brand new truck, power everything and it all works, leather, Dash looks brand new, It drives great, pretty sure it was garage it’s whole life paint is in great condition. I paid $9,800
You did get a deal there my friend.
I would post a picture but I don’t think I can’t figure out how
Also any recommendations on pillar gauges to get? How difficult are they to install?
Isspro ev1 if on a budget. Thats what I have. Isspro ev2 if not on a budget. The ev1's are good but fairly basic. The ev2's are a very nice step up.
Easier than installing an aftermarket radio, I'd say, for the electrical portion.  Drilling and tapping your exhaust manifold for EGT isn't too hard and that's possibly the most "complicated".  I have the ISSPRO EV2 gauges and really like them, including the directions for installation.
