Fuel Filter Housing Removal
- Replies 6
- Views 4.9k
Mopar1973Man 2 posts
Rowan24v 2 posts
dripley 1 post
wil440 1 post
Should of kept the stock filter. There is 3 reasons... 1. Fuel heater works in the winter time. The stock filter housing pull engine heat to warm fuel without out it gell up is possible.
When i was running the stock filter housing with my fass 100gph i was only getting 16 psi at idle and 11 at wot confirmed by two seperate fp guages, one at the fass and inbetween the filter housing an
I installed a fass 100gph a few months ago and its been putting a steady 19 psi at idle and 17 at wot, and for the longest time now ive wanted to remove my stock fuel filter housing and lift pump. So i got to removing the housing and that all went well as did removing the stock lift pump. I left the bracket in plate to support the ecm wires, but i was just wondering what i do with the WIF and Fuel heater wiring. Can i just leave them unplugged without touching anything else (and tape them up) or is there a fuse or something i need to remove so i dont light the truck on fire because of the unplugged fuel heater plug? Please help, need to know asap ?
