- Replies 9
- Views 1.8k
Mopar1973Man 3 posts
Wesley 3 posts
Me78569 2 posts
Threadzy 1 post
Popular Days
Ok setup just don't go any bigger. You basically are more like 3.42 gears to the ground. Optimal is between 3.55 and 3.73 final to the ground. Im running 30 inch tires which is 3.69 gears to the groun
Just out here in a pinch truck is an 02 vp truck with a quadzilla and s366 just put new 100 horse injectors it it and before with just tuner and turbo it made about 36psi boost and wot on hot tune wouldn’t exceed 1150 degrees now with new stix towing small tractor on car hauler it breaks 1100 pulling small tractor in stock tune, wondering if theres a tune out there that would help solve the problem or anything i could do in meantime before it gets water meth kit!
