Question about my VP44
- Replies 18
- Views 3.5k
Rather Be Wheeling 8 posts
dripley 6 posts
JAG1 2 posts
hdpwipmonkey 2 posts
Popular Days
TCW3 two stroke oil is very good additive. 1oz to the gallon. l use use super tech from W M. Other brands will work just as well.
Are you adding lubricity to the fuel to keep the VP44 healthy? Also the fuel pressure needs to stay above 14 even under hard pulls and excessive heat. If it's dropping below it's a slow death to the V
You can just replace the key. The key number is on the pump name plate I believe. I know it's on the pump somewhere. Surprised you did not have issues since install. That key is really smashed.
Hello,
So I went to run an errand with my 01 earlier after washing it and it fell on its face while driving down my street. Had a random speed sensor code that I cleared, but it wouldn't shut off even with the key pulled. I'm assuming it's the VP but I'm trying to find different opinions on the matter. I let it sit for 30 minutes and started it back up no problem. Everything came back to life. Turned it off again and re started it 20 minutes later and everything is fine. The pump is barely 2 years old and I'm reading 15 psi on my FASS. Any help would be appreciated.
