So I've been trying to get my truck going, and it's been hell.
I bought a set of 150hp injector tips, and used the pop tester at school to set the pop off pressures (all were at or just under 4500psi,stock recommended pressure), put them in along with new o-rings, and copper washers.
I got the truck started, and it idles great. But as soon as I roll on the throttle, it pops, sputters, tons of smoke. Its been doing this, and I've pulled it apart about three times checking to make sure I didn't rip or tear any o-rings during assembly.  So far everything looks good, everything is torqued to spec. Fuel pressure is a steady 20 psi.
Do I suspect the injection pump now? Or where else would you all recommend looking?
I will say when the truck was running, every now and then it would sputter badly, and tons of white smoke would come out of the exhaust. If I turned the truck off then on again, it would clear up. I suspect the timing piston is seizing up in the pump, but I'm not 100% sure either.
Thanks for the help!
  • Replies 13
  • Views 2k
Remove the Quadzilla test again. Like I found out it can foul the idle and other thing when my Quadzilla failed. If it still not working right then I would consider a new VP44.
Quadzilla is unhooked, and the only codes it's throwing is the map and boost sensor codes because quadzilla isn't hooked up.
I talked to a local mechanic, and he suggested try a crankshaft position sensor? I did replace the camshaft position sensor whilst trying to diagnose this problem.
BTW, which sensor feeds the tach signal? Mine is working, but I'm just curious.
The map and boost sensor are the same thing. Exactly what codes is it throwing?
I can't remember exactly, except they started with 16. It was the map sensor code and over boost protection(I think) code. Nothing about the pump or anything else
Thr map/boost codes are in the 230's. The 1600's have some pump and electronics codes. Knowing what they are would help.
I'll try and get them tonight
So I finally got the truck going again, after replacing the crankshaft position sensor,and got codes.
The pump is dead. Codes are as follows
P0216
P0237
P1693
Lost my MAP sensor when my pump failed back last Thanksgiving.
P0216 means it's dead, right?
Pretty much. Blue chip diesel has a great trouble shooting guide on pump failures. It is worth the read to be sure.
No longer capable of setting timing correctly in the given time. It will run still but the economy and power will be poor. Timing piston is more or less jammed and not moving properly any longer hence the code. More or less on a gas engine like taking the vacuum advance off a distributor and taking out the fly weights. Then set the distributor to a retarded timing and drive that. Power is low and economy is poor.
; ipsSettings['maxImageDimensions'] = { width: 1600, height: 1600 }; const ipsJsFileMap = {"communitymap":{"front_markers":"https:\/\/mopar1973man.com\/storage\/theme\/javascript_communitymap\/front_front_markers.js","front_showmap":"https:\/\/mopar1973man.com\/storage\/theme\/javascript_communitymap\/front_front_showmap.js"}};
